NWA50AX & NWA55AXE Email Log option disappeared
I've recently added both an NWA50AX and NWA55AXE to my network - both AP's are standalone management (not Nebula). When i first configured the AP's there was an option to enable a daily email with various log extracts. After updating the firmware to the latest (V6.29(ABYW.1) / 2022-11-04 15:20:39), the option for the e-mal version of the log has disappeared from both AP's. I'm guessing nthis is deliberate by Zyxel as the section of the manual regarding e-mailed logs has also changed. While it may not be a great loss to many people, it is a bit of a nuisance as I had enabled a simple daily email from the NWA50AX, but now have no way of amending or stoping the emailed log from being sent.
Anyone got any clues on how to re-enable the lost options, or to stop/amend the e-mail send from the NWA50AX? Or is this a case of downgrade the firmware, change the settings, then upgrade the firmware again….?
Thanks for any help…
Best Answers
Hi @NickU
There are two methods you can refer to stop the e-mail send from the AP.
Method 1:
SSH to AP and use the CLI below
Router> enableRouter# configure terminalRouter(config)# daily-reportRouter(config-daily-report)# no activateRouter(config-daily-report)# exitRouter(config)# exitAfter that, you can use CLI to check the daily report status:
Router# show daily-report statusOther CLI related to the Email Daily Report, you can refer to the attachment.
Method 2:
Downgrade the firmware to 6.25 patch 10, going to Configuration > Log & Report > Email Daily Report > Untick Enable Email Daily Report
And then, upgrade the latest firmware version to use.
Zyxel_Judy
Hi @NickU ,
You can download the full CLI-reference manual for the NWA/WAC/WAX Series here.
By the way, you also can download other materials at Zyxel Download Library
Zyxel_Judy
Hi @NickU
Method 1:
Method 2:
Zyxel_Judy
Thank you Judy, that was very helpful and has allowed me to amend the settings.
Out of interest, Is there anywhere that I can download the full CLI-reference manual for the NWA50/55 AP's?
Thanks again for your help 👍️
Nick
Hi @NickU ,
Zyxel_Judy
Thanks for the direct link Judy - I wouldn't have found it without it as the CLI reference doesn't appear in the download library when searching by either the NWA50AX or NWA55AXE.
Maybe it would be a suggestion to add it to the download lists for other AP's?
Thanks again for your quick and detailed help 😎
Hi @NickU ,
We'll add the NWA50AX/55AXE's CLI reference into Download library in the next time.
Thanks!
Zyxel_Judy
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
