NWA50AX & NWA55AXE Email Log option disappeared
NickU
NickU Posts: 5 image  Freshman Member
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
edited May 2024 in Wireless
I've recently added both an NWA50AX and NWA55AXE to my network - both AP's are standalone management (not Nebula). When i first configured the AP's there was an option to enable a daily email with various log extracts. After updating the firmware to the latest (V6.29(ABYW.1) / 2022-11-04 15:20:39), the option for the e-mal version of the log has disappeared from both AP's. I'm guessing nthis is deliberate by Zyxel as the section of the manual regarding e-mailed logs has also changed. While it may not be a great loss to many people, it is a bit of a nuisance as I had enabled a simple daily email from the NWA50AX, but now have no way of amending or stoping the emailed log from being sent.
Anyone got any clues on how to re-enable the lost options, or to stop/amend the e-mail send from the NWA50AX? Or is this a case of downgrade the firmware, change the settings, then upgrade the firmware again….?
Thanks for any help…
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,533 image  Zyxel Employee
    Hi @NickU
    There are two methods you can refer to stop the e-mail send from the AP.
    Method 1:
    SSH to AP and use the CLI below
    Router> enable
    Router# configure terminal
    Router(config)# daily-report
    Router(config-daily-report)# no activate
    Router(config-daily-report)# exit
    Router(config)# exit
    After that, you can use CLI to check the daily report status:
    Router# show daily-report status
    Other CLI related to the Email Daily Report, you can refer to the attachment.
    Method 2:
    Downgrade the firmware to 6.25 patch 10, going to Configuration > Log & Report > Email Daily Report > Untick Enable Email Daily Report
    And then, upgrade the latest firmware version to use.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @NickU ,
    You can download the full CLI-reference manual for the NWA/WAC/WAX Series here.
    By the way, you also can download other materials at Zyxel Download Library
    Zyxel_Judy
  • Zyxel_Judy
    Hi @NickU
    Method 1:
    Router> enable
    Method 2:
    Zyxel_Judy
  • NickU
    Thank you Judy, that was very helpful and has allowed me to amend the settings.
    Out of interest, Is there anywhere that I can download the full CLI-reference manual for the NWA50/55 AP's?
    Thanks again for your help 👍️
    Nick
  • Zyxel_Judy
    Hi @NickU ,
    Zyxel_Judy
  • NickU
    edited March 2023
    Thanks for the direct link Judy - I wouldn't have found it without it as the CLI reference doesn't appear in the download library when searching by either the NWA50AX or NWA55AXE.
    Maybe it would be a suggestion to add it to the download lists for other AP's?
    Thanks again for your quick and detailed help 😎
  • Zyxel_Judy
    Hi @NickU ,
    We'll add the NWA50AX/55AXE's CLI reference into Download library in the next time.
    Thanks!
    Zyxel_Judy
