zywall vpn license authentication
I have purchased a Mac license for a remote VPN after the free trial had expired. I am, however, unable to register my activation codes. I can't enter the codes into the downloaded software due to the free trial being expired.
What can I do? Thanks!
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 391  Master Member
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @Forini_5p4
    Hi, could you PM me your order ID, which SecuExtender software you've download and the screenshot where you can't enter the activation code?
    Let me check this issue for you.
    Thanks.
    Ivan
  • Zyxel_Ivan
    Dear @Forini_5p4
    Thanks for PM me the information.
    After reviewing the information, the root reason that you can't register your activation code is the software different from the license you've purchsed.
    Thanks.
    Ivan
  • That’s amazing thanks for sharing this is very useful to all. check this post
Service & License Help Center
