USG Flex 700 - Password change recommendation window - cannot be disabled
Finally I've changed the Admin password again after carrying out the firmware update. This let the error message gone.Nevertheless this error is still there and I assume it will be re-occur at the next FW update, irrespective whether I set this PW change reminder to "never" ask me again.0
Dear @USG_User
Thank you for choosing our USG Flex 700 product. May I know which previous firmware version the USG Flex 700 used? (I mean the one is before V 5.35.)On each login the USG Flex is showing a password change recommendation window which contains a drop-down handle where you could chose:Show this window "every time" or "never".And we always select "never", followed by OK button. But then the following error occurs very shortly:"Wrong CLI command, device timeout or device logout"And at the next login the same PW change note comes again.
Could you share screenshots of the whole login flow with us( Just as in quoted message that you mentioned. )? Does there any error messages that appear on the Monitor Logs?
Hi Jeff,after first start-up we updated to v5.32. Two days ago, after log-in, an update notification window appears and noticed us about a new firmware followed by the question whether the update should be downloaded and installed. Since the USG700Flex is not yet integrated in our production system, I chose YES and USG updated to FW v5.35.Since then the following PW change notification window appeared after each login:
Setting the drop-down box from "every time" to "never", followed by OK button, caused to a small grey error message window:"Wrong CLI command, device timeout or device logout"which automatically disappeared after 2 seconds.As said above, finally I have changed both admin passwords again. Now this window doesn't appear anymore on log-in. But I guess on next FW update it comes back as long as the Admin passwords won't be changed again, since the USG didn't accept the ' Remind me: "never" ' selection until now.0 -
Hi @USG_UserThanks for your feedback.The warning message “Strongly recommend changing them now to strengthen the secure access” reminds you to change the password to a more complex one. As for choosing the reminder to "never" and clicking OK then appear "Wrong CLI command, device timeout or device logout", it's unnormal.This message means the Web-GUI tries to issue CLIs to the ZySH daemon but timeout and failed.I tried to update USG Flex 700 from 5.32 to 5.35 at our lab but cannot reproduce this symptom.So, once this symptom appears again, please contact us and we will remotely debug this issue for you. Many thanks.0
Hi Jeff,
Today the error reappears again. When logging-in the Password Change Notification window is presented. Therein I set the combo box "Please remind me:" to "never" and clicked OK.
Then shortly a small CLI error window appears which disappears after 1 second automatically. That means that switching to "never" failed. And this caused that the Password Change Notification window is being presented on each login attempt again and again.
Hi @USG_User
Thanks for your update. Can you provide the remote Web-GUI link to us for further checks by private message? I will send a private message to you later, please check your e-mail inbox. We would like to check if it relates to ZySH daemon exists some problems. Thanks.
Hi @USG_User,
Since this symptom has resolved, we suggest that you continue to monitor it. If the problem occurs again, please let us know. Thank you!
Thanks Jeff, appreciate your good support
Was it a little "glitch" only, or could you find a bug in FW?
For the moment it works fine and the PW change notification screen doesn't appear anymore. I would come through again in case this behaviour reappears.
Hi @USG_User
When we accessed the USG Flex700 and the pop-up Password Change Notification appeared, we selected the option "never" and clicked "OK." After that, we were able to enter the Web-GUI normally. It seems that we were not able to reproduce this issue yesterday.
However, we did notice a log message indicating that the ZySH daemon was busy on 3/14, but the log does not prove that it was caused by selecting the "never" option. Therefore, we currently do not know the root cause of the issue. If the symptom occurs again, please let us know. Thanks.
I'd like to report that I've had this problem on my USG Flex700 for as long as I can remember. I'm on the latest 5.36(ABWD.1) firmware.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
