Sonos Play:1 speaker won't connect to EX3301 T0 router - Do I need Bridge mode?
OldBlade
in Home Router
If so, how do I configure my router to use Bridge mode?
Hello @OldBlade
Welcome to the forum.
Maybe not, but if you do then Bridge Mode up then how is described in the EX3301-T0 user guide that can be downloaded from Zyxel's Swiss distributor at https://www.studerus.ch/de/support/downloadcenter/
Is the EX3301-T0 putting out WiFi in 2.4 GHz band?
- The words about Sonos Boost suggests that the Sonos Play:1 only works with 2.4 GHz WiFi.
What colour is the status light on the Sonos Play:1 ?
see https://support.sonos.com/en-gb/article/sonos-led-lights?utm_source=doc-care&utm_medium=led&utm_campaign=en-gb-doc-care-led linked from https://www.sonos.com/pdfs/productguides/en-us/play1guide.pdf
Kind regards,
Tony
- 439 Beta Program
- 2.8K Nebula
- 197 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 318 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 450 News and Release
- 4.3K FAQ
- 93 Security Highlight
