Update of SBG3300-N000
dustypulver
When I attempt to update the firmware on an SBG3300-N000 to the latest version from SBG3300-N000_1.01(AADY.9)C0.zip, using the web interface, the 'revolving wheel' continues overnight.
I have tried unzipping it and just uploading the single V1.01(AADY.9)C0.bin but have the same result, as with the .bm and .rom files.
What am I doing wrong?
Hi @dustypulver
Can you reset the device(by pressing the reset button and hold for 5 seconds) and try to upgrade again after it was reset to system default?
5
Hi @dustypulver
What's the original firmware version before upgrading to SBG3300-N000_1.01(AADY.9)C0 ?
Did you try to reboot the SBG3300 and try to reconnect it?
The current (and original when purchased) is V1.01(AADY.6)
I have rebooted it and been forced to reconnect whenever the upgrade has failed.
Hi @dustypulver
5 -
Correction- uploading the .rom and .bm files is replied with a error that these are not valid and the .bin file had a reply "Do you want to update the firmware now?"To which I answer Yes and "Loading" appears until I reset the router several hours later.0
Thank you.A hard reset followed an upgrade then by uploading my system configuration has got it showing that the firmware is V1.01(AADY.9)
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 454 News and Release
- 4.3K FAQ
- 93 Security Highlight
