Once I switch the routers off, I'm not able to connect them to the SIM
fedeyoubear
fedeyoubear Posts: 1 image  Freshman Member
Hi, I've 2 Nebula 5G NR501 and I'm facing the same problem. I set up the router and I configure the SIM card and it's woks. But, once I switch off the routers and I switch them on, the devices are not able to connect to the SIM network anymore. The only possibility is a factory reset and to set the SIM again. It's happened in different locations, with different SIM providers and with both devices. So I wonder if maybe I'm missing some steps in setting the SIM.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    edited April 2023
    Hi @fedeyoubear ,
    Have you upgraded the NR5101 to 1.15(ACCG.3)C0 - the latest firmware version? Download at here: https://www.zyxel.com/us/en-us/support/download?model=nebula-nr5101
    Could you provide the screenshot of WEB GUI > Cellular Info before you switch off the router and after you switch on the router?
    By the way, could you share with us:
    - Which color of Internet LED after you switch on the router?
    - Do the routers work well after the factory reset?
    - Which reason led to you’d like to switch off/ on the router?
    Please enable customer’s Zyxel support by going to the left sidebar > Help > Support request > Invite Zyxel support as administrator, save the changes for us to check.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
