USG 110 / VPN Configuration Provisioning not working
I'm trying to get this to work on a USG110. Setting up an IKEv2 tunnel works fine, but the Configuration Provisioning does not.
I've configured the port for e.g. 448 or 4433 and configured a matching Security Policy allowing these ports to go to ZyWall itself.
But it doesn't work. on an iPhone, using Safari the page is blank, same device with Firefox (just to test), I get
"Forbidden", "You don't have permission to access this resource". The 'www setup" is set to use other ports than those I've tested with.
The log shows the traffic flowing fine to the USG ("ACCESS FORWARD")
What am I doing wrong?
Hi @mrwee
Currently, this VPN Provision Port feature is used for IPsec VPN client only, as below:
If the iPhone's Safari browser needs to download the VPN Provision file still needs to use the Web-GUI access port.
Hi @mrwee
Thank you for your inquiry. Could you please provide us with the remote Web-GUI link and device config file via private message for further checks? We would like to review your current device settings directly. We will send you a private message shortly, please check your email inbox.
Thank you.
Hi @mrwee
Additionally, please check whether the configuration provisioning has been activated, as below:
Thanks.
Configuration Provisioning has been activated, but I've only enabled IKEv2, not L2TP.
Hi @mrwee
Hi Jeff,
Thank you for the info. Since USG110 is out-of-service my assumption is that it will not be "fixed".
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
