The ability to clear "uplink currently operates at a lower speed 100mbps"
It will probably be a better idea to change that switch
just kidding.
Agree with you about the alert flexibility, but really, a switch that has that limitation won't let you get the best performance of your wireless local network.Just a suggestion, as it happened to me that many times I experienced a downgrade in the wireless speed and after some while I found out it was the switch port switching to 100mbps.
"You will never walk along"0 -
Don't really see the need for a better switch when the internet connection is only 20Mbps.0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
