GS1350-26HP EEE 802.3bt POE mode on Nebula.
We have a GS1350-26HP managed by Nebula. When we try to select de POE mode for a specified port in config, we cant select the 802.3bt (This option is not on the list). ¿It,s a Nebula limitaion or misconfig? Is important for us because we are connecting WAX650S Aps and need full power.
Hi @Infotecnika,
GS1350-26HP does not support 802.3bt, only GS1350-6HP supports it on ports 1&2. Furthermore, you could check more information on the specification page of the GS1350 series switch.
In addition, XS1930-12HP also supports 802.3bt. You could consider it since it provides 5G link speed for WAX650s.
Zyxel Melen0
Hi @Infotecnika,
Zyxel Melen0 -
Ok
Thank you for the info!
In this particular case it,s a simply scenario of two WAX650S and a GS1350-26HP.
We solved full power isse with 60w Zyxel,s POE Injectors for each AP. :) , I ve reserved the switch POE for other uses (VoIP etc…)
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
