Factory Reset of GS1920-48 results in GS1900-HP firmware load.
Casey
Casey Posts: 10 image  Freshman Member
edited March 2023 in Switch
While working with a finicky cMP Link Aggregation problem I noticed some ports were dropping. A restart didn't fix the problem, so I did a factory reset using the side button.
After the reset I navigated to 192.168.1.1 and LO! I now have downgraded my CS1920-48 to a GS1900-HP.
This I have rebooted and reset a number of times, and have tried to upload the last most recent firmware for the 1920. No go; it's stubbornly sticking to the GS1900-HP web ui.
How do I proceed to recover from this?
edit: FWIW I can no longer access this webUI via firefox as this firmware is using really old encryption standards.
«1
  • Casey
    edited March 2023
    The serial number on the GS1920's label is SCXXXXXXXBC
    the web ui shows S10XXXXXXX71
    There is no other Zyxel box on this small network
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,088 image  Zyxel Employee
    Hi @Casey,
    Could you provide the device photo (front panel and stickers) and the web GUI status page screenshot for me to verify?
    Zyxel Melen
  • Casey
    edited March 2023
    I'll have to do this in a sequence. first the screen shot.
  • Casey
    next the rack. after this I'll have to unrack this to get to the stickers on the bottom.
    PXL_20230330_162155778.MP.jpg https://us.v-cdn.net/6029482/uploads/64ESDSQ6YOLU/pxl-20230330-162212742.jpg
  • Casey
    I've been removing cables; I will have to find a quiet time to unrack this puppy. it's still routing as if it's a 48, but w/out access to the proper management UI
  • Casey
    edited March 2023
    this won't do, but I was able to squeeze a phone in htere and blind-shoot.
    I'll provide a better one after de-racking
  • JS87
    JS87 Posts: 20 image  Freshman Member
    edited March 2023
    Its not SCXXXXXXXBC. It is 5CXXXXXXXBC and matches the MAC-Address range of the switch in your screenshots from the WebGUI.
    The serialnumber is very blurry. It is the label over the MAC-addresses. The beginning matches with your WebGUI screenshot: S14…
    Found your thread on reddit and hope you find answers because thats very interesting!
  • Casey
    thanks @JS87. I find this most curious. since I was wedging my phone between two racked boxes it's no surprise how marginal the photos are. I'm going to re-reack after lunch, putting in a temp switch.
    I may take a movie and upload it somewhere to illustrate that I'm really not kidding about this situation.
    it would be weird if this were base-level fall-back firmware.
  • Casey
    edited March 2023
    …here we are. I'm going to be able to unrack in about an hour.
  • Casey
    edited March 2023
    and finally, @Zyxel_Melen the sticker on the bottom
    any thoughts?
