Licence for nwa55axe
Hi. Bought one of these to start a mesh network and wanted to manage with nebula but when I registered it asked me to setup a trial licence. Is there a way to use these without a licence as I wasn't expecting a licence cost when bought it?
thanks
Dear @Andrewy84
Greetings.
Yes, the Mesh Network is one of the built-in functions for the NWA55AXE and all Zyxel Access Points as well.
You don't need any licenses (even in the basic pack of Nebula Control Center) to enjoy the function.
Thanks.
Ivan
thanks. So is that the base licence?
Dear @Andrewy84
Yes, it is the base license.
The trial license allows you to use all Nebula Pro Pack features. You can find it through Organization-Wide > License & Inventory > Trial
After the trial license is finished, you can no longer use the pro pack feature; unless you purchase Nebula Pro Pack License.
The Mesh-Network is built-in function for the NWA55AXE and all Zyxel Access Points. No matter which Nebula Pack you're using.
You can learn more information about the different packs from the link below:
Thanks.
Ivan
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
