Switch XGS1210-12 - V1.00 Patch 6 Firmware Release
Zyxel_Adam
Zyxel_Adam Posts: 429 image  Zyxel Employee
Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
edited October 2022 in Switch New Release
Zyxel Switch XGS1210-12
Release Note
Sep, 2022
Firmware Version on all models
(Click Hyper link to download the firmware directly)
Zyxel XGS1210-12        - V1.00(ABTY.6)
New Feature and Enhancements
       None
Bug fix
No.
Bug fix
1.
Fixed BN_mod_sqrt() of OpenSSL to cause infinite loop issue by upgrading OpenSSL version.
2.
[eITS#220301352] Switch port speed will not change even click “Apply” button.
Please refer to the Download Link for more details.
Adam
  • davwheat
    davwheat Posts: 1 image  Freshman Member
    Well I tried a firmware upgrade to this version via the Web GUI and my switch has been bricked (flashing green SYS light for over 10 mins).
    Will need to return to Amazon and get a replacement now. Maybe I won't try an upgrade this time…
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    edited April 2023
    Hi @davwheat,
    Welcome to the Zyxel community!
    Could you share some information for me to clarify this problem?
    1. Did you use the .bix file to upgrade?
    2. Did you directly connect to XGS1210-12 and upgrade the firmware?
    If one of the answers is no, please notice the wrong upgrade method might damage your device.
    Kindly remind you to use the correct method to upgrade. And make sure no power disconnection will occur.
    In addition, are you able to access the Web GUI of your switch? If not, please get a replacement.
    Zyxel Melen
  • zyxel_rg
    zyxel_rg Posts: 2 image  Freshman Member
    Hi, before I brick mine too:
    1) Of course I would use the .bix file, what else?
    2) What means "directly connect to XGS…"? My computer is plugged into it "directly" by a network cable. And I'm using a Browser like firefox. What kind of setup would be "indirect"? Traversing multiple switches?
    And if there is such a high risk of "bricking" the switch: is there a dedicated documentation for the upgrade process?
    Regards
    /rg
  • Zyxel_Melen
    Hi @zyxel_rg,
    Thanks for providing your information.
    The firmware was fully tested before being released. And we did not receive the XGS1210 boot fail after the firmware was released for several months.
    If your switch still cannot boot up, please reference this link to submit RMA and get a replacement.
    After receiving a replacement, please follow the XGS1210 user's guide P.64-65 to upgrade firmware.
    Zyxel Melen
  • zyxel_rg
    @Melen: thank you for your feedback. I successfully updated all my switches without any hassle.
    Perhaps you should prevent incorrect firmware from being uploaded in the first place.
    /rg
