Sonos Play:1 won't connect with Zyxel EX3301 T0 router
OldBlade
OldBlade Posts: 2 image  Freshman Member
I have just had a Zyxel router installed and my Sonos Play:1 won't connect. The mobile I am running the Sonos 2 app on is connected to the router's wifi but when I try to update the network it says the speaker is not found. The same happens if I connect the speaker directly to the router with ethernet. The System option on the app is also greyed out.
Any advice please?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,603 image  Zyxel Employee
    Hi @OldBlade,
    Did you find Sonos support for help?
    Their community might have other users who have a similar problem as yours.
    Zyxel Melen
