connect to static route ip though ipsec vpn
hello,
i have spent hours trying to find a solution but i am still stuck. here is my problem
I have set 2 static route on our zyxel usg 110 to allow my users to use our ERP which is remotely hosted. Eveyring is ok when users are on site but when they connect trough the vpn that is set on the zyxel, they can't. Any idea of what to do ?
For the record, when i am connected to the local network, i can ping the remote lan (per exemple 10.100.1.1) but when I am connected through the vpn, i can't.
Any help woould be much appreciated
Regards
Pierre
One possible solution to this issue is to configure a "new IP pool" for remote VPN clients on the USG110, and then ensure that the ERP site is configured to route traffic from this "new IP pool" back to the local site.
You can refer to the article which provides detailed instructions on how to forward traffic to a branch site server after a client establishes a VPN tunnel:
Hi @mafois13 ,
Greeting Forum, please kindly check IPSec Phase2 "Local Policy" have the ip address of ERP.
If the issue still please kindly provide your configuration file by private message.
Thank you
Hi
Thanks for you tip bit it doesn't work. It even breaks the VPN :)
I'll am sending you the config file. Thanks for your help and time
Regards
Pierre
Hi @mafois13 ,
Thanks your time today, the issue have been resolved.
You have to add NAT rule for vpn address then ERP can be recognized that.
(src:client VPN address , dst: ERP server , SNAT)
Please feel free to contact us again if any concerns. Thank you
Hello
I had to change my zyxel firewall to a new more powerful version (USG FLEX 200) and I can't make it work again. Attached is a screenshot of my settings. Can you see what I am doing wrong ?
Regards
Pierre
Hi @mafois13 ,
As your private message said, You have resolved the issue after created two policy-routed.
That's great, please feel free to contact us again if any concerns.
Thank you
- 417 Beta Program
- 2.5K Nebula
- 160 Nebula Ideas
- 108 Nebula Status and Incidents
- 5.9K Security
- 331 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 259 Service & License
- 402 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 80 Security Highlight
