Does XGS1010-12 have VLAN passthrough?
Wik
Wik Posts: 2 image  Freshman Member
edited April 2023 in Switch
I am considering buying a XGS1010-12, the price is very affordable for a 10gbit SFP+ uplink!
My concern is that it is unmanaged and that therefore I will have problem with my VLANs. Does anybody know if it has VLAN passthrough so that it will keep the VLAN tag intact?
Thanks!
//Wik
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hello @Wik
    Thank you for your interest in the XGS1010-12. To answer your question, yes, the XGS1010-12 supports VLAN passthrough. This means that the switch will not modify or strip off the VLAN tag when the tagged frames pass through the switch. As the XGS1010-12 is an unmanaged switch, it does not perform any additional handling on the VLAN tag.
    We hope this information helps. Please feel free to reach out if you have any further questions.
    Best Regards,
    Nami
    Nami
    edited April 2023
    From what I can tell it will not so you have to look at XGS1210-12 or XGS1250-12
  • Zyxel_Nami
    Hello @Wik
    Best Regards,
    Nami
    Nami
  • Wik
    edited April 2023
    Thanks for the replies!
    It does seem that it fits my needs
    //Wik
