GS1920-48HP - Port Led Issue and link speed issue
Melen solved the mystery, I didn't realize during editing that I had accidentally pressed the button.
Thanks to everyone and especially thanks to Melen!!!😁
Hi @liuck1975,
It's happy to hear your mystery is solved. By the way, has the link speed issue also been solved?
Zyxel Melen0 -
Unfortunately, no, but I could not devote time to this problem because in the meantime I received many calls about other inconveniences and to install new wireless access points. I will have to try reconfiguring the switch.
Hi @liuck1975,
Did you connect your PC to the port that was connecting with the IP phone and get good throughput? If yes, the problem might be on the IP phone. I recommend checking the IP phone first.
Zyxel Melen0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 482 News and Release
