GS1920-48HP - Port Led Issue and link speed issue
2»
  • liuck1975
    liuck1975 Posts: 8 image  Freshman Member
    Melen solved the mystery, I didn't realize during editing that I had accidentally pressed the button.
    Thanks to everyone and especially thanks to Melen!!!😁
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,632 image  Zyxel Employee
    Hi @liuck1975,
    It's happy to hear your mystery is solved. By the way, has the link speed issue also been solved?
    Zyxel Melen
  • liuck1975
    Unfortunately, no, but I could not devote time to this problem because in the meantime I received many calls about other inconveniences and to install new wireless access points. I will have to try reconfiguring the switch.
  • Zyxel_Melen
    Hi @liuck1975,
    Did you connect your PC to the port that was connecting with the IP phone and get good throughput? If yes, the problem might be on the IP phone. I recommend checking the IP phone first.
    Zyxel Melen
