usg flex 200 firewall problem
kennethc
kennethc Posts: 1  Freshman Member
First Anniversary
failover not working if wan1 is connected there were no internet connection. By the way wan2 is connected.
    PeterUK Posts: 3,983  Guru Member
    edited April 2023
    You can setup routing rules with ping check with NAT of a LAN to WAN1 and another rule LAN to WAN2, want ping fails on WAN1 IP the route is disabled and goes to the next rule.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,343  Zyxel Employee
    Hi @kennethc
    Welcome to the Zyxel community. Please refer to this video to configure WAN Failover via Trunk feature on your USG Flex 200. Thanks.
