VPN2S site to site VPN problems
vpn2s
vpn2s Posts: 4 image  Freshman Member
edited April 2021 in Security
Hello all, please be polite because i'm trying to configure two VPN2S for the firs time, so i read guide and i think all it's ok when the green light of the connection was on, but unfortunately i can't ping remote lan and vice versa so the tunnel isn't working...
So the vpn is on, but, when in 192.168.1.x pc try to ping a 192.168.3.x pc not working and vice versa.
i try to post the screen with the 2 configurations, any help will be very appreciated.
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    Have you reviewed the routes on servers?
  • vpn2s
    Thanks Alfonso for the reply. I'll check then i'll post a screen.
  • vpn2s
    Here are the screen, i think it's correct...
    but ping one site to the other still not working...
  • Alfonso
    I am not an expert, but I do not see any misconfiguration.
    Can you provide more information? Logs?
    Another issue, review your NAT policy, remember that the flow between the internal networks must not be nated.
  • vpn2s
    Thanks all for the help, resetting and redoing the configuration did the trick!
    For some reason something went wrong with first save of one of the two configurations. Now VPN works and ping its ok!.
  • Alfonso
    Congratulations vpn2s :)
