Prioritize voip traffic
Diablo666
Diablo666 Posts: 3 image  Freshman Member
First Comment Nebula Gratitude
edited April 2021 in Nebula
Hi all,
I would like to know if it is possible to give VoIP traffic priority on other network traffic in the Nebula NSG 50?
Hope you can advice.
Thanks upfront.
Best regards
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Hello @Diablo666
    Welcome to the community!
    In current stage we do not support bandwidth priority for SIP traffic, may I know if you have encounter any issue?
  • Zyxel_Chris
    @Diablo666
    We have another way to fulfill your request, as below screenshot.
    In Gateway>Traffic Shaping, the source IP can be your clients and the destination IP is your SIP server, service port 5060 and with UDP protocol for instance.
    You can use scrollbar to reserve the bandwidth of it. Hope it can help you!!
  • Diablo666
    Hi and thanks! I was able to set it up. Could you tell me if it is possible to see in FW logs if this is working or this limit is being applied?
    Thanks and best regards
  • ivers
    ivers Posts: 45 image  Freshman Member
    First Comment First Answer Friend Collector Fifth Anniversary
    It's looks like it sorted at event logs of "system" category.
  • Diablo666
    I don't really understand what you mean. I want to see if there is actual traffic shaping being done for port 5060 or if I can see that the voip server is being reached from the voip devices.
    When I just select System category it doesn't show me much.
  • Zyxel_Chris
    @Diablo666
    Unfortunately, in current stage we don't have the relevant log with traffic shaping.
    I will move this request to the ideas section.
    Thanks for your suggestion!
Nebula Tips & Tricks
