Cannot move the widget "Site network status at a glance"
Hi @GiuseppeR,
You can click the reset button and the "Site network status at a glance" will be placed at the top line.
Zyxel Melen0 -
Hello @Zyxel_Melen
thanks a lot.
Just speaking about widgets… Is there a widget that could display only "wired devices" linked to the network like you can see in the widget "Wireless Clients"?
Is there a way to show multiple widgets regarding WANs for a specific site?
Having on sight WAN1 and WAN2 at the same time could be useful to understand how much bandwith is used just in time.
Hi @Zyxel_Melen
this is not a solution because resetting the widgets force the dashboard to place "Site network status at a glance" on the top, but destroy any other order/customization made to other widgets.
It seems to me that this is a bug.
Hi @GiuseppeR,
The widget "Site network status at a glance" can be moved to other places/spaces. But the new place/space must not have more than one widget, otherwise, you cannot move the widget"Site network status at a glance" to the new place.
I will help to create an idea post "Move the widget "Site network status at a glance" without restriction" for your request.In addition, I will PM you a video of how I moved the widget. Please check your message box.
Zyxel Melen0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
