WAH7706 - Disconnected from Internet
tonio
Hello, I just bought this device and trying to make it work.
I can connect, enter the sim code and all.
The screens and UI display 3G or 4G and the Network Operator, but the internet status is disabled.
I went throught the wizard, no luck.
There's an IP v6 allocated but no IPV4.
How should I proceed ?
Thanks.
Antoine
Did you try the sim card you put into WAH7706 is able to connect to the internet ?
Or can you change another Sim card and see is the result the same?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
