SNMP NEBULA
Hello, I would like to know how to configure the monitoring of the nebula antennas in zabbix.
I already enabled snmp in nebula, but how should I proceed now, and what information do I put in the device field in zabbix, or which ip do I point to?
  • Zyxel_Melen
    Zyxel_Melen Posts: 1,104
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hi @denysgoncalves,
    Welcome to the Zyxel community!
    You should make sure the SNMP community setting matches the setting on Nebula. Then you can poll the device information with the device's management IP address and the OID.
    You can find the Zyxel devices' MIB file in the Zyxel download library.
    Melen
  • yes this part is quiet, but where do I point?
    Do you have a specific IP, domain?
    the community part is fine, but since it's in the cloud, I don't know which IP I point the configuration to
  • Zyxel_Melen
    Hi @denysgoncalves,
    You should point to the device's management IP address, like 192.168.1.1, not the public IP on the Nebula device list. If your devices and the Zabbix server are using different IP subnet, you will need a router/firewall to route SNMP traffic.
    Melen
Nebula Tips & Tricks
