Nebula - Error saving SSID Schedule
2»
  • ticsystems
    ticsystems Posts: 87 image  ZCNE Certified
    First Answer First Comment Friend Collector Sixth Anniversary
    I have the same problem too.
    If you want I can give you access to review.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,585 image  Zyxel Employee
    @ticsystems ,
    Thank you for reporting the issue.
    We have other org/site to check the issue already. We will tell you once the issue is resolved.
    Zyxel_Judy
  • Zyxel_Judy
    Hi users,
    At the present, you can enable SSID schedule by using Nebula Mobile APP. Please go to SSID > Choose SSID > Advanced Setting > Schedule.
    Zyxel_Judy
  • SurfersParadise
    SurfersParadise Posts: 3 image  Freshman Member
    Zyxel_Judy that workaround work. add Schedule in APP, then edit in Browser.
  • Zyxel_Judy
    Hi users,
    We've fixed the issue as the error message when saving SSID Schedule, please implement your configuration.
    Thank you for your patience!
    Zyxel_Judy
  • Marcolino
    Marcolino Posts: 7 image  Freshman Member
    Hello Judy,
    I wanted to follow up on this support request to let you know that with your help, we were able to successfully resolve this issue.
    Want to express my sincere gratitude for your excellent support and solution implementation.
    I also appreciate your prompt and open communication throughout this issue, and I have always found you to be very personable - great :-)
    Thanks for your perfect support Judy,
    Marcolino
    Captain MESO (Dipl. Ing. Markus Ehrl) | Solution Architect | Principal Consultant Enterprise Infrastructure | Escalation Engineer | Global Microsoft Practice
    MESO Products | Via Vairano 113 - Residenza Orizzonte Blu | CH-6575 San Nazzaro / Vairano | Phone Germany: +49 (89) 381 64-185 | Phone International: +41 (91) 7800-434 | Fax: +41 (91) 7800-438 | markus.ehrl@mesoproducts.de | www.mesoproducts.de
    TEAMS SIP Address for Presence/Voice/Videocall: markus.ehrl@mesoproducts.de
    CCFO: @zyxel_judy
Nebula Tips & Tricks
