SNMP NEBULA
Hello, I would like to know how to configure the monitoring of the nebula antennas in zabbix.
I already enabled snmp in nebula, but how should I proceed now, and what information do I put in the device field in zabbix, or which ip do I point to?
Hi @denysgoncalves,
Welcome to the Zyxel community!
You should make sure the SNMP community setting matches the setting on Nebula. Then you can poll the device information with the device's management IP address and the OID.
You can find the Zyxel devices' MIB file in the Zyxel download library.
Zyxel Melen0 -
yes this part is quiet, but where do I point?
Do you have a specific IP, domain?
the community part is fine, but since it's in the cloud, I don't know which IP I point the configuration to0 -
Hi @denysgoncalves,
You should point to the device's management IP address, like 192.168.1.1, not the public IP on the Nebula device list. If your devices and the Zabbix server are using different IP subnet, you will need a router/firewall to route SNMP traffic.
Zyxel Melen0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
