Cannot move the widget "Site network status at a glance"
GiuseppeR
GiuseppeR Posts: 644 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
finding a new widget named as in the object is interesting but if I try to add it to an existing Company the Zyxel Nebula dashboard places it at bottom line.
I tried to move it to another position but it seems stuck down there.
Is there any help?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,532 image  Zyxel Employee
    Hi @GiuseppeR,
    You can click the reset button and the "Site network status at a glance" will be placed at the top line.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    thanks a lot.
    Just speaking about widgets… Is there a widget that could display only "wired devices" linked to the network like you can see in the widget "Wireless Clients"?
    Is there a way to show multiple widgets regarding WANs for a specific site?
    Having on sight WAN1 and WAN2 at the same time could be useful to understand how much bandwith is used just in time.
  • GiuseppeR
    Hi @Zyxel_Melen
    this is not a solution because resetting the widgets force the dashboard to place "Site network status at a glance" on the top, but destroy any other order/customization made to other widgets.
    It seems to me that this is a bug.
  • Zyxel_Melen
    edited April 2023
    Hi @GiuseppeR,
    The widget "Site network status at a glance" can be moved to other places/spaces. But the new place/space must not have more than one widget, otherwise, you cannot move the widget"Site network status at a glance" to the new place.
    I will help to create an idea post "Move the widget "Site network status at a glance" without restriction" for your request.
    In addition, I will PM you a video of how I moved the widget. Please check your message box.
    Zyxel Melen
Nebula Tips & Tricks
