VPN2S site to site VPN problems
So the vpn is on, but, when in 192.168.1.x pc try to ping a 192.168.3.x pc not working and vice versa.
i try to post the screen with the 2 configurations, any help will be very appreciated.
Hi @vpn2s,
I use Wizard and follow your configuration to set local policy 192.168.1.0/24 and 192.168.3.0/24 on each VPN2S.
VPN is connected. PC 192.168.1.2 and PC 192.168.3.3 can ping each other successfully.
No extra routing rule is required.
Try to reset the configuration file and use Wizard > Welcome to IPsec VPN Setup to configure site to site VPN again.
Attached are the configuration files for two VPN2S. You can also load the configuration files to run the test.
username: admin
password: Aa12345
5
Have you reviewed the routes on servers?0
Thanks Alfonso for the reply. I'll check then i'll post a screen.0
Here are the screen, i think it's correct...
but ping one site to the other still not working...0 -
I am not an expert, but I do not see any misconfiguration.
Can you provide more information? Logs?
Another issue, review your NAT policy, remember that the flow between the internal networks must not be nated.0 -
Hi @vpn2s,
username: admin
password: Aa12345
5 -
Thanks all for the help, resetting and redoing the configuration did the trick!
For some reason something went wrong with first save of one of the two configurations. Now VPN works and ping its ok!.0 -
Congratulations vpn2s
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
