Zyxel NWA5123-ac Bridge Mode
Nmes
Nmes Posts: 3 image  Freshman Member
edited May 2024 in Wireless
I need to set up an Access Point to connect to a WLAN-network (wich I'm not managing) and pass that network through to LAN devices.
I was told NWA5123-AC would do the trick. I'm not used to setting up Access Points. But from what I understand in the manual the NWA5123 in Repeater mode can only connect to another Zyxel AP in Root mode?
Basically my question is. Can NWA5123 connect to a random WIFI and pass it through it's LAN port?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,582 image  Zyxel Employee
    Hi @Nmes ,
    It appears that you are referring to the wireless bridge function. This function can only be utilized when both Root AP and Repeater AP are Zyxel wireless bride supported models as below.
    You’re right. NWA5123 in Repeater mode can only connect to another Zyxel AP in Root mode, and it can establish the Mesh with any Zyxel AP.
    Zyxel_Judy
  • mMontana
    mMontana Posts: 1,487 image  Guru Member
    If it can do that, you can look for "client mode". The AP acts like… wireless card for network cables (more or less)
  • Zyxel_Judy
    Hi @Nmes ,
    Zyxel_Judy
  • Nmes
    Perfect!
    Thank you both for your answers!
