do drones interfere with nebula or ap wifi?
[Deleted User]
in Nebula
i am setting up nebula cloud and an AP wifi lan. Will my neighbor's drone interfere?
Hi @DrFAME ,
It is possible that your neighbor's drone could interfere with your AP in case that drone models use frequencies as 2.4 GHz or 5 GHz. The level of interference that you may experience will depend on several factors, such as the distance between your AP and the drone, the strength of the drone's signal, and the quality of your AP's hardware and antenna.
To minimize the risk of interference, you could try:
- Positioning your AP as far away as possible from the drone's flight path
- Using a Wi-Fi analyzer tool to find the best channel and then set the channel manually for your AP
- Using DCS to let AP scan and choose the best channel for your AP. The configuration path: Configure > Access points > Radio settings > DCS setting
Zyxel_Judy
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
