SCR50AXE Not Working In Nebula
Pook
Pook Posts: 151  Master Member
First Comment First Answer Friend Collector Nebula Gratitude
Anyone had a luck getting this to work? I followed the setup guide but appliance is always offline in NCC. Devices connected to it have internet access though. Tried with 2 different WAN connections offering DHCP and PPPOE with same result.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,369  Zyxel Employee
    Hi @Pook
    To check if it is the DNS related issue, could you help to provide us the remote access to the device,
    to check further information, I have PM you , please check your message box.
  • [Deleted User]
    [Deleted User] Posts: 3  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    Hey @Pook,
    Please take a look at this guide and if it doesn't work, please state what's not working:
    https://support.zyxel.eu/hc/en-us/articles/11055188589458-SCR50AXE-Configure-in-Nebula-and-Getting-Started
    Thanks!
  • Pook
    Not sure what happened but the device is all ok now. Only another 7 to setup and get out the door this week :-)
  • dpazout
    dpazout Posts: 3
    Hello, is it possible to manually assign IP adress via MAC adress?
    Is it possible to access management via web management page? Where to set password?
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    edited May 2023
    Hi @dpazout ,
    It does not have DHCP static binding at current design.
    As for password configuration, it is at Site-wide > Configure > Site Settings
  • dpazout
    dpazout Posts: 3
    Tx for the answer.
    And … I had in my Wifi network some IoT devices.
    I set the same SSID and password.
    Those devices appeared for few hours … but, they lost connection, and now all of them are disconected.
    Why?
  • dpazout
    dpazout Posts: 3
    Hi @Zyxel_Cooldia, now I am not able to connect to wifi any older notebook. :-(
  • Zyxel_Jerry
    Hi @dpazout
    Does the wifi cannot be detected by all of the clients?
    Or the issue only appear an older notebook?
    If the issue only happen on the older notebook, please try to upgrade your driver.
Nebula Tips & Tricks
