Multiple WAN widgets
GiuseppeR
GiuseppeR Posts: 660 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited July 2024 in Nebula Ideas
Hello
I would like to ask to enable the possibility in the dashboard to have multiple WAN widgets. It could be useful to see at a glance the usage on network balancing when you install firewall with multiple WANs inside a Company.
Please support that. 😁
1 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @GiuseppeR,
    Thanks for sharing your idea with us~
    Anyone who also likes this idea, please vote or leave a comment.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    We have a widget called "WAN utilization."
    It can show you the WAN utilization for WAN 1 & WAN 2.
    Can it fulfill your requirement? Or do you have another idea? Please share with us.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    unfortunately it is not the same because with that widget you have to click on the arrows to see the values of bandwith. Having 2 or more widgets each for a specific WAN could be perfect to see at a glance how it is going load balacing and the usage of internet for that selected Company.
    At your disposal.
  • Zyxel_Melen
    Hi @GiuseppeR,
    Thanks for your feedback. I'm clear now.
    Zyxel Melen
Nebula Tips & Tricks
