Strongvpn locks up USG60W
PeterUK
PeterUK Posts: 3,799  Guru Member
edited May 2023 in Security
USG60W V4.73(AAKZ.1)
So I have been trying out VPN provides and for what ever reason setting up a LT2P Strongvpn on it connecting up locks up the USG needing a reboot and unplug from the internet to disable the L2TP rule.
But on another note my FLEX200 setup in the same way has no problem nope it too locks up
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,422  Zyxel Employee
    edited May 2023
    Hi @PeterUK,
    Is 2FA enabled on L2TP VPN?
    Hi
    No this is L2TP as in you setup in Object > ISP Account and in network > interface > PPP
  • Zyxel_Emily
    Hi @PeterUK,
    Please help us clarify the issue.
    1. What it the previous firmware version on this USG60W? Does the same issue exist when you use previous firmware version?
    2. Please send the web GUI access of this USG60W or USG FLEX 200 to me in private message. We'd like to check the debug log on the device. Thanks!
    It happens on firmware V4.73(AAKZ.1) and V4.73(AAKZ.0)ITS-22WK50-r106743
  • mMontana
    mMontana Posts: 1,428  Guru Member
    Following as a hounddog. I'm questioning myself if the memory leak is part of the problem here.
    Yes maybe but it does not happen to other L2TP tunnels just Strongvpn for some reason…
  • mMontana
    L2TP tunnels and StrongVPN use the same cyphers kit?
    It uses MSCHAP-V2 but L2TP the tunnel for all traffic is not encrypted.
    I'm guessing its some Configuration Request the USG does not like maybe IPv6
  • Zyxel_Emily
    Hi @PeterUK,
    Thanks for the remote access. We are able to see the symptom remotely on your device.
    The date firmware is sent to you in private message. Please update the USG FLEX 200 to this version and we will monitor the status remotely again. Thanks!
    Well I give in going round and round with Strongvpn they just say not supported by their guides I just don't get how privatevpn.com and hideipvpn.com both don't list Zyxel but L2TP works just fine with them, I just have to think no one uses L2TP at Strongvpn and thats the reason it don't work.
