NBG7510 - please add the ability to add Static Routes
tonygibbs16
tonygibbs16 Posts: 979 image  Guru Member
50 Answers 500 Comments Friend Collector Fifth Anniversary
edited July 2024 in Consumer Idea
Dear Zyxel,
Please could you add the ability to create static routes to the NBG7510 router.
I think that this feature is necessary so that I can make my Home Networking work properly and have the ability to route the different subnets in my Home LAN.
- currently there are 2 subnets, 192.168.1.0/24 and 192.168.123.0/24.
I can get from 192.168.123.0/24 to 192.168.1.0/24 but I cannot route in the other direction.
- Pings and Tracert time out.
Kind regards,
Tony
1 votes
Active · Last Updated
  • tonygibbs16
    Maybe this is not needed after all.
    I found that if I added a Trust Domain for 192.168.1.0/24 into the NBG7510 and enabled Ping, HTTP and HTTPS for WAN under Remote Management, then I could Ping successfully the NBG7510 on 192.168.123.1 and could login to the web console from a host on 192.168.1.0/24 subnet.
    So configuration issue for me.
    Kind regards,
    Tony
