unable to create vlan trunk to switch
I have multiple vlans configured in zyxel firewall.
I want to create trunk from firewall to my switch so that all tagged vlans are send to switch. Unable to find a solution
Hello @ashwinvijay
For example:
Firewall
LAN1 192.168.1.1/24
VLAN10, ge3/10,192.168.10.1/24
VLAN20, ge3/20, 192.168.20.2/24Switch
port 1 Tx VLAN10, VLAN20 PVID1 -> connect to Firewall ge3
port 2 Ux VLAN10 -> connect to PCResult: PC can access VLAN10
Did you encounter anything when deploying VLAN topology?
If you have VLANs of firewall then they are tagged to go to a switch that then VLAN's then out the ports as untagged where needed.
May I know your scenario or topology? and what's your Firewall/Switch VLAN setting?
Hello @ashwinvijay
For example:
Firewall
LAN1 192.168.1.1/24
- 603 USG FLEX H Series
- 481 News and Release
