Connection drops periodically for a few seconds
Hello everyone,
I used 2 ZyXEL devices:
- Firewall: USG20-VPN
- Switch: GS1920-24HP
Two devices have been Nebula connected.
But my network is unstable, the connection drops periodically for a few seconds, maybe mili seconds, and then back to normal. This problem occurs continuously, about 10 times in 1 hour or more.
This is the result when I try to ping the default gateway:
I don't know why, please help me.
Thank you.
Maybe bad cable?
Thanks for your answer. The cable has been changed, but the issues do not fix.
Any solution for this?
You could disable Green Ethernet on the switch.
Can you test without the switch to the USG port?
Thanks, Peter.
But I can't find the settings for disabling Green Ethernet on the switch.
I using Nebula cloud.
If connect FLEX without swtich, the issue still exist ?
Oh, I think the issue from firewall. the issue still exist with only firewall.
Any solution for this issue? Thank you0 -
Hi @ktd_sproud ,
Greeting forum, Have you changed network cable ?
Please kindly provide diag-info by private message. Thank you
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
