Zyxel DX5301-B2
StuartMayor
StuartMayor Posts: 2 image  Freshman Member
Hi.
I have a Zyxel DX5301-B2 router. Firstly, where can I get the latest firmware for this router? The Zyxel website doesn't even seem to acknowledge this router exists.
Secondly, I have a concern with this router that the Web Configuration GUI is listening on both ports 80 and 443 on both the LAN and WAN interfaces. I do not want it listening on the WAN interface and, ideally, I would like it to listen on a port other than the standard HTTP(S) ports.
According to the documentation, there should be a "Remote Management" screen where I can configure this. This screen seems to be missing from my Web Configuration GUI. How can I access this screen?
Thanks in advance
