Zyxel DX5301-B2
Hi.
I have a Zyxel DX5301-B2 router. Firstly, where can I get the latest firmware for this router? The Zyxel website doesn't even seem to acknowledge this router exists.
Secondly, I have a concern with this router that the Web Configuration GUI is listening on both ports 80 and 443 on both the LAN and WAN interfaces. I do not want it listening on the WAN interface and, ideally, I would like it to listen on a port other than the standard HTTP(S) ports.
According to the documentation, there should be a "Remote Management" screen where I can configure this. This screen seems to be missing from my Web Configuration GUI. How can I access this screen?
Thanks in advance
Hi @StuartMayor
Welcome to the forum.
is a user guide that covers the DX5301-B2 router.
Remote Management is under Management, see the following picture:
I hope that this is helpful.
Kind regards,
Tony
Sorry it is under Maintenance.
Also, what version of firmware are you running?
Kind regards,
Tony
Hi Tony,
Thank you for getting back to me.
It would seem I don't have that entry under Maintenance in my GUI.
I also guessed at URLs like http://192.168.1.1/RemoteManagement but nothing seems to work.
I've also tried Telnet and SSH with no joy.
I'm running firmware V5.17(ABUL.0)C0. I was hoping changing to a different firmware might make it reappear but there's no trace of any firmware online
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 406 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
