Port Forword Zyxel VMG8623-T50B
Good evening, while I'm doing port forwarding, the port still no open , can you help me , i sent photos e.g.
A friend told me that he has a virtual interface that's why you don't unlock the port
  • michalis_12345
    michalis_12345 Posts: 5
    I'm pretty sure the Originating IP is the problem
    do you mean her?
    PeterUK Posts: 3,770  Guru Member
    Can Originating IP be changed to any? or your WAN IP
  • First Thank you
    i have static ip 69.169.227.150
    ip 192.168.1.100 is my pc I have the program and I want to open it port 8000
    I can't get the manual for your router so what are the options when adding a port forward?
  • michalis_12345
    do you mean her?
    in red I think is wrong
    ip my pc
    Yes thats your Server IP address setting you got right but Originating IP should not be the same as that.
  • sorry , i dont understand 😁 , i burn 🤬
Service & License Help Center
