Device temperature has exceeded system threshold
LDI
LDI Posts: 11
image  Freshman Member
edited May 2023 in Security
My USG-500 keeps shutting down.
I get the message that the device temperature has exceeded threshold.
the router is managed via nebula:
Router# debug hardware fan-get
Sensor[0]:75 degree
Sensor[1]:50 degree
Sensor[2]:57 degree
FAN[0]:6914 RPM
FAN[1]:0 RPM
FAN[2]:0 RPM
FAN[3]:0 RPM
what can i do?
Best Answers
  • LDI
    LDI Posts: 11
    on the wall.
    PeterUK Posts: 4,830
    image  Guru Member
    Not sure on the threshold on my Flex200 I get
    Sensor[0]:73 degree
    Sensor[1]:43 degree
    Sensor[2]:47 degree
    FAN[0]:0 RPM
    FAN[1]:0 RPM
    FAN[2]:0 RPM
    FAN[3]:0 RPM
    which is idle no fan
    You might have a heatsink loose?
    That box on the top of the USG might be blocking vents?
  • LDI
    LDI Posts: 11
    I moved it and it is still overheating.
    Sensor[0]:72 degree
    Sensor[1]:48 degree
    Sensor[2]:54 degree
    FAN[0]:6878 RPM
    FAN[1]:0 RPM
    FAN[2]:0 RPM
    FAN[3]:0 RPM
    Router#
«1
    image  Guru Member
    Where have you put the the USG-500?
  • LDI
    LDI Posts: 11
    on the wall.
  • LDI
    LDI Posts: 11
    What is the threshold of the router? There is lots of other equipment with no issue.
    image  Guru Member
    Sensor[0]:73 degree
    Sensor[1]:43 degree
    Sensor[2]:47 degree
    FAN[0]:0 RPM
    FAN[1]:0 RPM
    FAN[2]:0 RPM
    FAN[3]:0 RPM
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 988
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    image  Zyxel Employee
    Hi @LDI ,
    The device will dump warning message if sensor exceed 80 °C.
    The ventilation holes of FLEX500 are located on both sides, It is recommended to remove the appliance above away to ensure proper ventilation.
    Thank you
  • LDI
    LDI Posts: 11
    Can you add fans to the Flex500?
  • LDI
    LDI Posts: 11
    Sensor[0]:72 degree
    Sensor[1]:48 degree
    Sensor[2]:54 degree
    FAN[0]:6878 RPM
    FAN[1]:0 RPM
    FAN[2]:0 RPM
    FAN[3]:0 RPM
    Router#
  • LDI
    LDI Posts: 11
    Sensor[0]:72 degree
    Sensor[1]:48 degree
    Sensor[2]:54 degree
    FAN[0]:6878 RPM
    FAN[1]:0 RPM
    FAN[2]:0 RPM
    FAN[3]:0 RPM
    Router#
  • mMontana
    mMontana Posts: 1,514
    image  Guru Member
    @Zyxel_Kevin In my life i NEVER put in that orientation a Zyxel Firewall. Only "plane", on feets or on rack.
    Is that positioning supported/advised?
