unable to create vlan trunk to switch
I have multiple vlans configured in zyxel firewall.
I want to create trunk from firewall to my switch so that all tagged vlans are send to switch. Unable to find a solution
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @ashwinvijay
    For example:
    Firewall
    LAN1 192.168.1.1/24
    VLAN10, ge3/10,192.168.10.1/24
    VLAN20, ge3/20, 192.168.20.2/24
    Switch
    port 1 Tx VLAN10, VLAN20 PVID1 -> connect to Firewall ge3
    port 2 Ux VLAN10 -> connect to PC
    Result: PC can access VLAN10
    Did you encounter anything when deploying VLAN topology?
    PeterUK Posts: 4,268 image  Guru Member
    If you have VLANs of firewall then they are tagged to go to a switch that then VLAN's then out the ports as untagged where needed.
  • Zyxel_James
    May I know your scenario or topology? and what's your Firewall/Switch VLAN setting?
  • Zyxel_James
    Hello @ashwinvijay
    For example:
    Firewall
    LAN1 192.168.1.1/24
    Switch
