NWA5123-AC memory leak detected
Sinna
Sinna Posts: 3 image  Freshman Member
edited May 2024 in Wireless
It seems like after enabling 802.11k/v in the NXC2500 AP Profile, all NWA5123-AC AP's report the following:
  • Priority: alert
  • Category: system
  • Note: Memcheck
  • Message: Memory leak detected
The message seems to be followed by an augmenting number.
All AP's are running FW 6.10(AAZY.10).
I can't find any information about this behavior, so I post it here.
As I expect a memory leak in the end results in a reboot (due to lack of memory), I'd like to see this fixed.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    Hi @Sinna ,
    We based on the models and steps that you mentioned to reproduce the issue, however there is no log related memory.
    By the way, note that from 2023-01-31, NWA5123-AC’s technical support and RMA service will no longer be supported by Zyxel. Recommend you refer to WAC500 as a replacement.
    For more information, please refer to this EOL link
    Zyxel_Judy
    Untitled Image
  • Sinna
    @Zyxel_Judy: Thanks for getting back so quickly, really appreciated.
    I didn't realize the AP's are already EOL.
    The memory leak messages are not raised immediately after enabling 802.11k/v and it seems to be related to the number of clients that associate with the AP raising the alert.
    In the meanwhile I've disabled 802.11k/v to see if the situation stabilizes.
