Import HTTPS certificate to Zyxel 1930-10 to avoid ssl error.
2»
  • wisepds
    wisepds Posts: 9 image  Freshman Member
    I think.. here is your answer…
    As you can see when i push "Import" all system block.
    I can't ping after import the certificate.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    Hi @wisepds,
    We released a date code firmware to fix this problem.
    I will send the firmware to you, please check your message box.
    Zyxel Melen
  • wisepds
    IT'S WORKING!!!
