Configure SMTP
Samm
Samm Posts: 8 image  Freshman Member
edited May 2023 in Security
good afternoon, can you help me
I am configuring mail alert in USG20W-vpn, but it does not send the messages, it shows the following error message:
1-Sending event/alert log to mail server has failed. [count=3]
2- Sending event/alert log to mail server has failed
Could you share an image of how it should be configured. I am registering an account for: example@outlook.com
which smpt and ports should i use.
Beforehand thank you very much
  • Zyxel_Cooldia
    Hi @Samm ,
    Welcome to Zyxel community. The smtp server settings as below,
    Server: smtp-mail.outlook.com
    Port: 587
    Encryption : STARTLS
  • Samm
    Hi, thank you for you answer. I made the configuration, but the error is the same. maybe be something a security on email security setup?
    should be easy to configuration, but I do not what can be.
    I already tried with different tls options and nothing does
    Firmware: V5.35(ABAR.0) / 2022-12-27 21:03:06
    PeterUK Posts: 4,429 image  Guru Member
    Outlook don't let allow Mail From say USGFLEX200@anyname.co.uk so SMTP Authenticate User Name and Mail From must be the same.
  • Samm
    this is my configuration.
    it will be OK😥
