[NEBULA] how can i deny access between client?
Carlos4311
is there anyway to restrict clients to not able to see other people's device in the network?
Hi Carlos4311,
You can do so by enabling L2 isolation in the Authentication page, which you also need to input your gateway MAC for internet access, if you want to allow specific client to be seen in the network, just in put it's MAC in the list as well.1 -
thank you , it can work!0
I do it but it doesn't work....the client don't surf on internet
Hello @solidsnake74
I think you've saved the gateway's WAN interface MAC address if the outcome is no internet.
Idealy you should input the MAC of the gateway port where the AP is connected to, that is where the internet traffic is going to/from.
You can look it up under cmd "arp -a" to find the right gateway MAC on a windows client.
Here's a link of an FAQ on L2 isolation:
https://businessforum.zyxel.com/discussion/830/how-to-block-traffic-between-guest-and-employ-ssid/p1?new=1
-Dean0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
