Is WMM coming to Nebula?
Hi @TAPTech
I've moved this post to the ideas section. By the 802.11n standard WMM is required, so by default it is enabled, but it is not configurable to other types in Nebula APs.
As a suggestion, if you are to configure QoS for VoIP, by making the settings on the LAN side (e.g. uplink switch or router) should result in more significant effects than WMM typically speaking.
5
Hi @TAPTech ,
Currently we did not have WMM in the roadmap, however I can transfer your request to the ideas section if you like:) .
Yes, please do. We are pleased with the WMM Voice capabilities of the zyxel access points and have had good luck using them with VoIP, which we did not expect. So we want more of it!
Hi @TAPTech
5 -
Hi TapTech!
i'm also interested in using VOIP handsets over nebula, and cant find and settings. Did you mange or have to configure any thing to make your handsets work? I need to ensure WMM Power Save and QOS is enabled and configured, just cant find any settings0 -
It looks like those features are not currently support in Nebula. We have a small fleet of USG40 and USG60 series routers, which we use as WiFi controllers. Nebula looks like it is getting better and better- we will most likely be moving over for the next hardware refresh. Hopefully they have some of these features implemented by then. For now, it doesn't look like a capability.0
- 588 USG FLEX H Series
- 477 News and Release
