SCR50AXE Not Working In Nebula
Hi @Pook
To check if it is the DNS related issue, could you help to provide us the remote access to the device,
to check further information, I have PM you , please check your message box.
Hey @Pook,
Please take a look at this guide and if it doesn't work, please state what's not working:
https://support.zyxel.eu/hc/en-us/articles/11055188589458-SCR50AXE-Configure-in-Nebula-and-Getting-StartedThanks!
Not sure what happened but the device is all ok now. Only another 7 to setup and get out the door this week :-)
Hello, is it possible to manually assign IP adress via MAC adress?
Is it possible to access management via web management page? Where to set password?0 -
Hi @dpazout ,
It does not have DHCP static binding at current design.
As for password configuration, it is at Site-wide > Configure > Site Settings
Tx for the answer.
And … I had in my Wifi network some IoT devices.
I set the same SSID and password.
Those devices appeared for few hours … but, they lost connection, and now all of them are disconected.
Why?0 -
Hi @Zyxel_Cooldia, now I am not able to connect to wifi any older notebook. :-(
Hi @dpazout
Does the wifi cannot be detected by all of the clients?
Or the issue only appear an older notebook?
If the issue only happen on the older notebook, please try to upgrade your driver.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
