NR7101 No lan / wifi connection evan after factory reset
Hi @tundria ,
Have you set the hardware (PoE and SIM) up successfully?
No present in lan at 192.168.1.1
In case you can't access the router via 192.168.1.1, please check your laptop have the IP in the same subnet with router?
no wifi Zyxel_CE19 SSID
The SSID default as disable status. To enable SSID, please press WIFI button and hold more than 5 seconds.
On the other hand, in case you can access to the router WEB GUI, you can enable SSID button.
Note that: NR7101's 2.4G Wifi is for configuration only
Zyxel_Judy
Hi @tundria ,
Zyxel_Judy
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
