High CPU load for switches GS1900-24E
Hi @Yuri_S,
Welcome to Zyxel Community!
Based on your description, I assume that there is a loop in your network environment.
Please help to verify if the "Loop Guard" feature is enabled, because if the feature is disable. In the monitor page for loop guard will not display if there is a loop occur in the environment.
Steps:
1. Access GS1900-24E via web.
2. This page is to activate the loop guard feature.
Configuration > Loop Guard
3. Choose and check the port that would like to enable loop guard then click edit.
Configuration > Loop Guard > Port
4. In this page it will display which port will be modify. Configure enable to activate loop guard and for the action is you may choose what will the switch action after detecting a loop event. In the example I've used "Shutdown and Log".
Configuration > Loop Guard > Port > Edit
5. This page is to verify the status for loop guard configuration.
Verification:
1. If there is a loop detected, it will display like the status below.
Example: Port 4 & 5 have loop.
Monitor > Loop Guard
2. For the log status will display like the figure below.
Monitor > Management >Syslog
Thanks for supporting Zyxel!Zyxel_Jonas
https://us.v-cdn.net/6029482/uploads/78HOOSV0BUBI/240828-nebula-27s-intentcommunity-homepage-1920-x-400.jpgDon't miss this great chance to upgrade your Nebula org. for free! https://bit.ly/4g2pS9L
Good day.Many thanks for provided solution.I confirmed, that Loop Guard was enabled before this issue happened, but there were no loops detected.Also I rebooted both switches yesterday evening and issue was repaired. I don't know what was reason of this high CPU load, but after reboot I have CPU load about 15-25% for both switchesI will monitor status for few next days and will update this topic.Thanks in advance.Yuri.0
So, few hours ago this issue returns.Now I again have high CPU load on both switches. Need you support to investigate given issue.Thanks in advance0
With the help of command show process activity I determined, that process cli makes this high CPU load.is this abnormal activity of my Putty-client or something else?
Hi @Yuri_S,
Thanks for the show process status.
I'll PM you to retrieve more detail information.
Thanks.Zyxel_Jonas
Good daydo we have any updates?Best regards.0
Hello :-)
I have exactly the same situation here. Same as above: Loop Guard is active - but no loops detected. The only difference is, that we see this issue on a GS1900-8. I use V2.40(AAHH.2) | 06/05/2019 as firmware, I replaced the wires and of course I took a brandnew GS1900-8 but all fails. After booting the switch, it stays for 1-2 hrs. afterwards again 100% CPU. Checking the SSH console, I can see that 3 processes (called "CLI") consume more than necessary. The load average goes up to 1.55. So, dear ZyXEL, how are we going to fix this?
BR,
Marco
Hi @AFT
Welcome to Zyxel community!
For starters, we'd like to point out the cause has nothing to do with Loop Guard.
We resolved the original case by mirroring packets towards switch's management and it turned out there were periodical "malicious" packet generated by certain scheduled anti-virus/scanning task on client's end device. The huge amount of packets simultaneously rushed into CPU and hanged the switch.
The solution is to use "Remote Access Control" (Configuration -> Management -> Remote Access Control) restricting a desired access IP range. It prevents untrusted packet from CPU processing.
Hopefully it helps.
Zyxel_Lucious
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
