FLEX200 / recommended device temperature
Our FLEX200 reports back a constant, yet toasty 67°C CPU temperature (via Syslog, at info-level / severity: 4).
The rack it sits in is in an air conditioned room, it has no active components next to it top or bottom and airflow is given.
CPU average is reported as 6 (percent I guess) and memory at around 40.
Is that a normal temperature for those conditions? Or might there be an issue?
What is the maximum / shutdown temperature for the readout?
Manual states "max. 40°C ambient temperature", but since we are now around 25°C at max in that room, I am a bit worried for the coming summer and also the overall longtime stability of the FLEX200.
Hi @StefanZ
Thanks for your inquiry.
Currently, the maximum shutdown temperature is 85 °C.
The 6% CPU usage with 67 °C belongs to a higher temperature.
We suggest you can check whether there are other devices are nearby your USG Flex200.
If so, please separate them at a safe distance to avoid the high-temperature issue(as the following user guide described).
Besides, you can use CLIs to check the current CPU and temperature.
Router> show cpu average
Router> show cpu all
Router> show cpu status
Router> debug hardware fan-getHere is another discussion about the high temperature, it could provide you with some hints.
Thanks.
Thanks for the reply.
The FLEX200 is at the bottom of the rack, 2 Slots above it are empty (4 height units), there is nothing below or to the sides and the air is cooled to 25°C currently.
Also the table states that the FLEX200 isn't suited for rack mounting, though it comes with rack mount brackets included… Talking about "mixed signals" :-)
So what temperature range should be expected for my scenario?
And what can cause the overheating?
I would put my money on a poorly attached heat sink…Current results in command line:
CPU utilization: 7 %
CPU utilization for 1 min: 3 %
CPU utilization for 5 min: 4 %Router> debug hardware fan-get
Sensor[0]:68 degree
Sensor[1]:38 degree
Sensor[2]:43 degree
FAN[0]:0 RPM
FAN[1]:0 RPM
FAN[2]:0 RPM
FAN[3]:0 RPMWhen I get back to the appliance next time, I will move it to a new, mobile rackmount so I can test it outside the server room at general ambient conditions. But those are likely to be way worse soon than the server room, since summer is coming.
I guess the Flex200 could of had top ventilation like the USG60
Would be great, if anyone else using a FLEX200 shared their device temperature to have a comparison.
I get this but my Flex200 is not in the best place may have to strap on some fans😋
Router# debug hardware fan-get
Sensor[0]:72 degree
Sensor[1]:40 degree
Sensor[2]:44 degree1 -
Just tried to find the device temperature of my USG FLEX50.
Seemingly the CLI cannot show me those (no commands for
fan).And the
cpu-temperature-monitorcommands (page 52 of the V5.36 FLEX50 CLI reference PDF) don't seem to exist for this device.0 -
I don't think lower end models give a temperature read out.
Thanks!
Well so mine ain't too special – still rather hot for an appliance CPU.
Is it possible to obtain the CPU temp through SNMP queries? Thank you
Best regards0 -
Hello @StefanZ
The USG Flex50 doesn't support the CLI Router# debug hardware fan-get. Thanks.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
ZCNE Certified
